Hi there - firstly thanks for reading this!
I'm making a DIY cnc router using some Nema23's and a TB6560 board off ebay. Z and X axis work fine, but Y-axis will only travel in one direction. I've tested the y motor on the x output and it works fine so it's not the motor wiring. I've used the multimeter to confirm I get an output from the parellel port and cable on pin 3, which according to the rubbish manual I got with the board is the Y Dir output...
I can see only two options:
1. The manual is wrong and Pin 3 is not the Y-dir input to the board - can anyone confirm this or suggest a different pin?
2. My board doesn't work!
Regards,
Martin
	15-01-2011 #2
Do you have the 3 or 4 axis board?
Also try swaping or reseating the optocouplers for that axis."If first you don't succeed, redefine success"
	08-06-2012 #3
	15-01-2011 #4
did you get it from savebase?
there is no such thing as a stupid question, just stupid answers !!!!
	20-01-2011 #5
	21-01-2011 #6
Got it locally (New Zealand) appears to be same board as yours
	21-01-2011 #7
	16-01-2011 #8
Thanks for the replys - it's a 3 axis board I got off ebay. I'll try swapping the opto couplers as suggested.
	20-01-2011 #9
Just for an update. I tried swapping my opto couplers around and the Y-axis TB6560 chucked its dummy out and popped! It now has a big crack in it. I've been corresponding with the supply who seem very helpful and have agreed to have it back and replace it with a new one. Fingers crossed the new one will work perfectly and I'm be able to continue :)
	20-01-2011 #10
I HAD THIS PROBLEM oops (caps lock) and found I had loaded the wrong motor direction output port. My Z axis was trying to dig a hole in the table as it would only go down. Stopped being excited about getting movement and reset to the correct port. As there are not many outputs and you will have used most of them it should not take too long
cheers
Graham
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
1 axis tb6560 any good?
By lazzymonk in forum Motor Drivers & ControllersReplies: 15Last Post: 08-08-2012, 07:58 AM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
By Mad Professor in forum Items For SaleReplies: 1Last Post: 04-01-2011, 06:54 PM -
Motors and Board? Problem.
By m.marino in forum General ElectronicsReplies: 7Last Post: 17-04-2009, 10:47 AM
