You need to connect one par of coils (or phase) between 1a and 1b and the other to 2a/b. Whether or not you put the coils in series or parallel depends on your drivers/motor. If the a+ and a- are your motor wires(?) then they connect to 1a/b on the driver (doesn't matter which way round, that only reverses the motor rotation direction).
If you're not sure then post what motors and drivers you have so I can help you more precisely.
15-01-2011 #2
Hi, thanks for reply, im pretty sure i know what you mean but i have sigma 8 wire motors which i have wired in parallel, to give me a+-b+- and these boards http://www.routoutcnc.com/10asingle.html .
15-01-2011 #3
15-01-2011 #4
They are old nema 42s, sorry no data but 34s are more powerful as they have better magnets than the old 42s
15-01-2011 #5
16-01-2011 #6
Its an early Bridgeport BOSS they are fitted with steppers but the later ones had servos
15-01-2011 #7
yeh i went with the higher amps as the motors need about 8 or 9 i have been told and they are geared 1 to 1 so they need plenty of tourqe, but speed is not a great concern of mine so hopefully it should be ok.
I'm guessing they must be nema34 then? Do you have a link to the datasheet out of interest?
16-01-2011 #9
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
Driving 2 steppers from one driver?
By Dan Brown in forum Stepper & Servo MotorsReplies: 2Last Post: 20-12-2009, 07:26 PM -
FOR SALE: Stepper Driver. 4x Steppers. Supported Rails.
By Conan257 in forum Items For SaleReplies: 3Last Post: 24-10-2009, 07:31 PM
