Thread: Web Goblin cnc has begun
Not sure how good a central heating pump would be. You would be reducing its normal flow rate down alot but most of them have adjustable speeds so you could slow it down a bit.
Jazzcnc. I am using distilled water. Normal water just causes too many problems.
"No windows in your shop" Does it have bars where the door should be?:lol:
Ian
01-09-2011 #2
Yes and my overalls have nice stripes on them. .:whistling:
Seriously thou I do have a great big steel door with no windows. . . And even that doesn't stop the scum bags.
A few months ago my workshop was broken into but thank fully we caught one of them.! . . wont go into details but lets just say we got the stuff back and real justice was served. .
01-09-2011 #3
I compensated for that by putting the tank of water on a shelf at about the same height as the spindle.
I think Luke meant 1000 litres per hour...
I don't think distilled (or more likely de-ionised) water is required if, as you have done, you don't change the water. Once the water has deposited the calcium carbonate there is nothing more to deposit - it's essentially de-ionised. That does to an extent depend on the volume of water you are using (and where you live) as clearly if you have a 1000 litre tank there are a lot of ions it there to start with, and vice versa.
I take it you signed the relevant petition then recently.
01-09-2011 #4
BUILD LOG: It's begun....
By Washout in forum DIY Router Build LogsReplies: 158Last Post: 07-06-2015, 10:03 AM
