    When I jog my Y axis from end to end there is a patch in the middle where the table/screw make a grinding noise but it still travels and motor is not loosing steps. Its the same area each time but it doesn't make noise to the same extend on its way back. What needs adjusting?
    Have you put any lube on it ?
    its dripping with lube, plus this happens only over a few centimeters on the Y.
    Humm i dont really know what that could be then sorry.
    Isnt a "dovetail" a type of wood joint?
  6. yes, but exactly the same shape is used as an accurate slide mechanism. I suppose he should have said 'slacken the gibs' as they are the plates that control the loading on the dovetail... see pic
    More info on your machine will definitely get people going in the right direction.
    This question is like asking
    " I have a blue car here so will these wheels fit on it? "
    Not a lot of info.
    Is it recirculating ballscrews?
    What type of drives are you using ?
    Do you have ballscrew lead screws or acme thread with anti-backlash nuts
    You need to give a lot more info so we can correctly diagnose the problem
  1. Super sieg x3 conversions
    By dazza in forum Milling Machines, Builds & Conversions
    Last Post: 19-02-2014, 10:28 AM
  2. CONVERSION: Sieg Super X3 conversion
    By Sooty in forum Conversion Build Logs
    Last Post: 06-03-2013, 02:29 PM
  3. Super X1L Suggested Accessories ?
    By ecat in forum Milling Machines, Builds & Conversions
    Last Post: 05-10-2010, 12:07 AM
  4. Sieg Super X3
    By Gary in forum Milling Machines, Builds & Conversions
    Last Post: 25-10-2008, 10:58 PM
  5. Super X1 conversion - CNC Fusion kit
    By bruce_miranda in forum Sieg Milling Machines
    Last Post: 19-09-2008, 01:43 PM
