That makes two of us.
Make a walnut what?! But yeah, running it off two 12v 92Ah batteries for the moment. Not got a power supply which would supply anything like enough for this. Idling at 3100rpm it consumes 94w. 45w ish at 1500 rpm... that implies almost 200w just to spin the thing at full speed let alone cutting!
20-01-2011 #2
looks great, i love how simple these thing are :)
walnut whip ! .... shit joke.... sorry :)
owch, but as M250cnc phil said to me not to long ago"give your bearing a chance to run in at low (ish) speed before you start flapping about heat" or "drag" in your case94w
im getting on fine using 350w 12v on my 1700w motor, i dont think you will need to throw 6000w at yours if your using it on your routerLast edited by blackburn mark; 20-01-2011 at 08:28 PM.
22-01-2011 #3
I did the mount today, not the neatest of things I've made with the rotary table but it works:
Spinning...nice effect:
I ran the motor in for about 5 mins on 12v, soon got bored of that (I'll leave it running properly tomorrow). So I tried carefully grasping the motor body with some kitchen roll to protect my fingers - couldn't stall it, not even close
. It merely drew 550w and about 53 amps. I'll have to think of a safer way of testing the power at higher voltages.
I think I'll stick with the batteries for now unless anyone can point me to a 50v PSU that can deliver a LOT of current. Maybe a few of those switching PSUs people have been using for steppers on eBay...Last edited by Jonathan; 22-01-2011 at 04:30 PM.
22-01-2011 #4
I was under the impression your mill was under cnc control why the RT ?
Its a temperature thing if it doesn't get hot just keep increasing the speed in increments.
Sounds like mum & dad are gonna have a big leccy bill coming.
Phil
22-01-2011 #5
I took the steppers off the milling machine and put them on the router. Didn't want to put them back just for one part. Rotary table was also the most accurate way I could make the hole for the spindle, not having a boring head.
That's good, the bearing didn't get hot at all. ESC warmed up a little but that's all. I'll leave it running on 3100rpm for a while today and see what happens.
Hmm, didn't think of that - and nor have they :naughty:
The batteries I'm using to power it were going to be charged from my wind turbine. If only I had space to mount it...
I measured the runout again now it's mounted properly. I put a 10mm cutter in and measured 0.03mm about 10mm from the collet. If I put the DTI on the collet chuck itself it reads 0.01mm.
22-01-2011 #6
4 jaw chuck on the lathe ?
Are you measuring the outside or the inside of the chuck for runout ?
You should be measuring the inside and i would measure at the extremes of the taper to see if you have different amounts of runout at the two points.
Phil
22-01-2011 #7
It wouldn't fit easily on the lathe - it's only a C3 mini lathe with 4" 4 jaw chuck. I probably could have got it to fit, but it wasn't worth it since I needed the rotary table to do the semicircle on the outside anyway. Wish I had a lathe like yours...made so many things on the same one at school.
I used the lathe with 3 jaw chuck for a few of the bearing mounts for the screws - carefully designed the shape to fit the chuck easily.
I measured the runout inside. I'll try again like you said.
Just tried cutting with it. 7mm two flute cutter and some scrap aluminium. Using 0.5mm depth/width of cut it was happy. Sometimes 1mm, machine is a bit too wobbly to do more at the moment. I'll post pictures in a minute to save a thousand words...
The motor drew 30w extra whilst cutting, 100w idle.Last edited by Jonathan; 22-01-2011 at 04:33 PM.
Diy Brushless Spindle
By blackburn mark in forum Brushless Spindles & MotorsReplies: 181Last Post: 08-06-2021, 03:50 PM -
Spindle motors resonable options
By Web Goblin in forum Spindles & Drive MotorsReplies: 15Last Post: 20-11-2016, 03:31 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
FOR SALE: 400w panasonic ac brushless servo motors and drives
By gavztheouch in forum Items For SaleReplies: 3Last Post: 29-12-2011, 03:04 PM -
FOR SALE: Metabo 710W 230V Electric spindle, stepper motors, Tr nuts 20x4
By Vladimir_MD in forum Items For SaleReplies: 3Last Post: 09-04-2010, 05:24 PM
