Thread: backlash mack3
I don't use it as I have ballscrews so I don't have to.
Phil
Sent from my HTC Desire using Tapatalk
28-01-2011 #2
I almost always use it. If, for instance, you're drilling an array of holes it will clearly make a difference to the accuracy - unless you're careful with the Gcode.
I've found in some instances it is of limited value since the backlash wont be a constant value.
Be careful with the velocity and 'shuttle accelaration' settings. The motors will loose steps with too low a setting for the latter, however to high a value will make the motion less smooth.
Have you got two ballnuts preloaded on each screw then? Or just sufficiently low backlash to ignore it with one?Last edited by Jonathan; 28-01-2011 at 02:07 AM.
28-01-2011 #3
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM -
Is this an example of what backlash can do?
By Minnican in forum Machine DiscussionReplies: 19Last Post: 06-03-2011, 08:59 PM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Positive backlash???
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 18-08-2010, 05:04 PM -
Sieg C3 backlash problem
By Cret in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 08-09-2009, 07:18 AM
