Thread: Opinions
    remarkably similar looking to the Chinese stuff on ebay - Not that I'm suggesting this is Chinese, nor that there'd be anything wrong with it if it was...
    Thanks for the replies guys.
    There are a few videos of similar machines on youtube. It seems to be capable of doing everyhting that I would desire of a CNC mill.
    Now for the next question:- I already have access to Autocad and I am pretty proficient with this software. However, what other software would I require? From my limited reading, I think I may need two separate pieces of software. One to drive the mill (Mach 3???) and another to convert the Autocad drawing files into something that Mach 3 can import.
    Am I on the right track??? Any recommendations?
    Ian
    The machine posted in my first link, is supplied with A 300W spindle. That doesn't sound very powerful to me. My main useage would be thin plate alu. Do you think it would cope?
    Quote Originally Posted by p1lts View Post
    Yes, the process is...
    CAD creates drawing of part
    CAM creates NC control file from drawing
    Controller (Mach3 / EMC2 etc) Takes the NC file and makes the machine move according to the instructions therein.
    You always need the controller but you can create the NC (AKA gcode) file in a text editor.
    Autocad is fine for the drawing, the CAM program really depends on what you want to make and what your budget is. I tend to recommend CamBam which is fairly cheap, easy to understand, will import DXF files from Autocad and has a 40 go full function trial. If you need to take complex 3d models from Autocad and create the NC code directly from them then you may require something (much) more expensive but CamBam is a good introduction to the basic process so time spent looking at it won't be wasted.
    it looks like a reasonably chubby motor so i would have thought the torque would be quite good but i guess there is no real way of saying without knowing more about it/ how its wound
    iv an outrunner that looks a similar diameter and will happily cut 0.5mm depth in alli 3000rpm 3mm single flute, the power supply is 350w but im pretty sure its drawing nowhere near that
    edit: the one you show in the link will only run as low as 5000rpm not perfect but i would have thought doable with small tooling :)
    Hi Mark
    Apologies. I am now looking at the slightly larger machine http://www.premiersign.co.uk/proddet...rod=BC-400-300 which has the 300W motor and a variable speed of 1-9000rpm.
    I'm just a little concerned how easy it would be to change the spindle to a different type if I had too at a letr date.
    Thanks again for all the help
    speed of 1000-9000rpm
    ahhh!! that sounds better :) i would have though you would be fine with that
    if you have access to a lathe making your own spindle would be a cheep option.. easy to make one to fit whatever spindle housing you already have, its not rocket science and they work quite well, there are a couple of threads on here that will talk you through the task but unless your after using larger cutters and heavy cuts im pretty sure the spindle on the BC-400-300 will be fine
  8. The Following User Says Thank You to blackburn mark For This Useful Post:
  1. Bench lathe -opinions sought
    By cropwell in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 14-03-2014, 06:32 AM
  2. new build opinions required
    By george uk in forum Gantry/Router Machines & Building
    Last Post: 04-02-2014, 10:46 PM
  3. Doosan CNC's? Opinions wanted!
    By Adtech in forum Milling Machines, Builds & Conversions
    Last Post: 30-09-2011, 02:08 PM
  4. opinions on buying cnc milling machines
    By DGH in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2009, 04:47 PM
