Thread: Opinions
  1. #9
    speed of 1000-9000rpm
    ahhh!! that sounds better :) i would have though you would be fine with that
    if you have access to a lathe making your own spindle would be a cheep option.. easy to make one to fit whatever spindle housing you already have, its not rocket science and they work quite well, there are a couple of threads on here that will talk you through the task but unless your after using larger cutters and heavy cuts im pretty sure the spindle on the BC-400-300 will be fine
  2. The Following User Says Thank You to blackburn mark For This Useful Post:
  1. Bench lathe -opinions sought
    By cropwell in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 14-03-2014, 06:32 AM
  2. new build opinions required
    By george uk in forum Gantry/Router Machines & Building
    Last Post: 04-02-2014, 10:46 PM
  3. Doosan CNC's? Opinions wanted!
    By Adtech in forum Milling Machines, Builds & Conversions
    Last Post: 30-09-2011, 02:08 PM
  4. opinions on buying cnc milling machines
    By DGH in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2009, 04:47 PM
