Page 6 of 7 FirstFirst ... 4567 LastLast
  1. #51
    Can you share it with me?
  2. #52
    [I have a more important problem now. I removed 2 Roland pcn-3000 chips on board and reassembled them wrong. Exploding fuse and exploding mosfer . I'm very sad and don't know if I can fix it
  3. #53
    the fuse has blown
  4. #54
    Does this help?
  5. #55
    Does this help?
    Hi Robin, I have a Roland PNC-3000 machine, and I am working on trouble shooting some issues with it. Currently, the motor PCB is not receiving the necessary 12V supply voltage. When I supply the 12V using an external supply, the motor can be switched on, but I have been unable to figure out why the motor PCB isn't getting 12V. Another issue I am having is the spindle speed display is not working. Could you please send me a picture of the relevant circuit diagrams? Are the manuals and circuit diagrams available online somewhere?
  6. #56
    This is the PSU, the rest would need some considerable finding and sorting out.
    The spindle speed starts with a reflective sensor looking up at the bottom of the front pulley and connects to the PCB behind the speed control knob and to a rather primitive bar graph on the display panel.
  7. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  8. #57
    Thank you for the PSU schematic that is very helpful! I will start with verifying the PSU is working properly and work from there.
  9. #58
    I got a junk PNC-3000. While researching how to use it, I noticed something wrong with the z-axis DRO.
    The value only increases when I raise or lower the z-axis.
    I need a schematic for repair. And I want to know how to use it, so can you share the manual and other documents?
    Best regards
  10. #59
    Doddy's Avatar
    mitarashidango
    I'll assume the DRO is a quadrature encoder - you'll get two outputs typically labelled "A" and "B". With quadrature encoding one of those signals is considered a "clock" (a pulse indicates travel), and the other indicates the direction of travel. It sounds like one of the outputs has failed (wire snapped, etc?), and it's just counting the clocks regardless of direction of travel. In theory you can test the quadrature outputs, assuming they're driven high/low with something as simple as a multimeter - each output will toggle high/low at the resolution of the DRO - you won't be able to (easier) test each discrete step, but you can check that some movement toggles the status easily enough. Be aware that you want the DRO in circuit to allow any decoder pull-ups to operate.
  11. #60
    I'd be more inclined to retro-fit with a stand-alone controller with integral display and keypad which takes ISO G-Code.
  1. NEW MEMBER: Yorkshire based modding / hacking noob says hello
    By dynamis_dk in forum New Member Introductions
    Last Post: 27-02-2014, 11:03 PM
  2. FOR SALE: Roland CAMM3 PNC-3000 Desktop Mill
    By danielbriggs in forum Items For Sale
    Last Post: 25-01-2012, 06:14 PM
  3. FOR SALE: For Sale! Roland PNC 3000 milling machine
    By fidia in forum Items For Sale
    Last Post: 26-07-2011, 10:07 PM
  4. NEW MEMBER: Hi From Oxfordshire - with Roland CAMM3 machine
    By rowifi in forum New Member Introductions
    Last Post: 15-02-2011, 05:04 AM
  5. Cheap for hacking
    By Robin Hewitt in forum General Discussion
    Last Post: 21-11-2008, 01:30 PM
