    Me again
    I replaced the 20mm linear shafting and it certainly tightened it up.
    Replaced the X, Y ball screws and doubled up on the nuts to add a 1kN preload :naughty:
    The ebay M8x.75 half nuts I bought on Monday haven't arrived. Can't thread the ballscrews 'til I have the nuts or it suddenly becomes guesswork for the length and die closure.
    A very nice man at bellevillesprings.com gave me half a dozen washers to preload the thrust bearings. Their £15 minimum order translated in to 150 pcs :whistling:
    The metal for the splash guards did arrive so I will probably start on that.
    Pic is the bed and saddle upside down.
    I've extended the table 2" forwards with a lip. Then I decided that driving my Warco mill using MSDOS was a right PITA after seeing what Windows 7 can do with this thing.
    I have the new software about 80% complete so I'm going to do that before I cut the splashguards. It takes a DXF file, converts it to a cut and then drives the mill.
    Back in a few weeks, if I don't get sidetracked again :whistling:
    Robin
    Me again
    Splash guards fitted and looking a bit '70s retro.
    An IP65 sealed box bolted to the right hand end is the suds tank, I'm using the Tee slot as a gutter.
    Next, sealing it with gasket compound and cutting some slots in the bed so I can fit tee nuts from above and improve the drainage.
    Robin
  1. NEW MEMBER: Yorkshire based modding / hacking noob says hello
    By dynamis_dk in forum New Member Introductions
    Last Post: 27-02-2014, 11:03 PM
  2. FOR SALE: Roland CAMM3 PNC-3000 Desktop Mill
    By danielbriggs in forum Items For Sale
    Last Post: 25-01-2012, 06:14 PM
  3. FOR SALE: For Sale! Roland PNC 3000 milling machine
    By fidia in forum Items For Sale
    Last Post: 26-07-2011, 10:07 PM
  4. NEW MEMBER: Hi From Oxfordshire - with Roland CAMM3 machine
    By rowifi in forum New Member Introductions
    Last Post: 15-02-2011, 05:04 AM
  5. Cheap for hacking
    By Robin Hewitt in forum General Discussion
    Last Post: 21-11-2008, 01:30 PM
