Thread: Speed and Feeds
Hello Folks,
Starting to enter the interesting
 world of cutting conditions and setting up for the materials I use instead of the canned stuff that came from BobCAD with V23. I figure that learning it now with this will help when I get T-Flex CAD/CAM and set up an in depth set for the range of materials I am cutting.
So what I am looking for is either a good old fashion discussion on differing materials and cutters/endmills (HSS or Carbide) or some good sources for learning both the reasoning as well as the math behind this. I know the old fashion way some tell you to learn, which is run it as fast as you can till it breaks and back off. That is a very expensive learning curve and one I would rather not go down.
To get it started I have noticed that my 1mm single flue carbide endmill will only take about 180 to 200 mm/min at 5k rpm on a Kress with a cutting depth of not greater than 1.5mm. While my 2mm single flue carbide endmill will handle 450mm/min in one direction with chatter and just a little bit of chatter in the opposite feed direction. Cutting depth on that is not yet fully tested, though will handle 2mm depth no problem in Maple.
I tend to cut hardwoods, softwoods, Acrylic, HDPE, Delrin, with the odd bit of soft alli'. I am looking to be able to cut Brass and PB102 to PB104 Phosphor Bronze in the near future as well as possibly Nickel Silver. So anyone wish to help a member loose a bit more hair trying to truly understand this stuff.
Look forward to a learning curve.
Michael
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Feeds and speed guide/pocket book
By maritimesbob in forum Marketplace DiscussionReplies: 3Last Post: 10-11-2013, 09:38 AM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and feeds deep drilling
By Razorab in forum Sieg Milling MachinesReplies: 13Last Post: 10-02-2013, 09:00 PM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
