    Yeah got my CNC running beautiful great did some good cuts then.......................... the Y axis went tight for some reason I freed it off now I dont have movment in Y have I damaged the board?? no sign of burning or smell, Y led lights up on the board when I toggle I have swapped the X and Y leads over Y motor is ok :cry:
    Quote Originally Posted by gorbo View Post
    Does the X motor work on the Y axis driver?
    Is the Y motor receiving any current, i.e. does it lock up when switched on but not moving?
    OK grab this....... Y would not work as above post, then I tried on a different Mach3 set up it worked yet all the settings are the same, strange or what? pleased though but I still need to fix Y axis trouble is I have just enclosed it in a cover so I will be busy for the next few days, thank god im unemployed where would I have time for work! :rofl:
  1. angular contact bearings - back to back, further apart
    By dsc in forum Linear & Rotary Motion
    Last Post: 05-01-2014, 10:59 PM
  2. Step drill bits (where to get) ?
    By Gytis in forum Marketplace Discussion
    Last Post: 07-08-2013, 12:04 AM
  3. Step 4 router
    By John S in forum Milling Machines, Builds & Conversions
    Last Post: 11-08-2009, 04:16 PM
  4. Pulley kit to step up a stepper RPM
    By HankMcSpank in forum Belt Drive, Pulleys & Timing
    Last Post: 11-07-2009, 09:49 PM
  5. Step clamp
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:39 AM
