Thread: CAM Software for lathes
21-03-2011 #11
Yes Easymill can rotate parts in 4 and 5 axes - but not while cutting.
I am surprised by your response - you say 'what credibility do you have ?' yet you do not explain what you mean - from my web research there seems to be confusion between rotation axes and 2D/2.5D/3D.
And more specifically a great deal of confusion as to what constitutes 2.5D!
With Easymill as far as I am aware the axis is rotated but doesn't cut while rotating.
When the part has been rotationally positioned, the cutting starts in 2.5D.
Isn't 5 axis work holding and machine stability beyond hobbyists' budgets? So why is 5 axis an issue for hobbyist software?
I need many clamps just to hold the small pieces I do in x,y,z - so with 5 axes I am not sure how the work pieces would be securely held - unless I get a very expensive machining centre.
FOR SALE: Sliding head cnc lathes £5k
By jpcnc in forum Items For SaleReplies: 1Last Post: 29-05-2011, 09:00 PM -
Lathes
By Web Goblin in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 18-02-2011, 10:32 AM -
Mini lathes - possible to turn stainless?
By HankMcSpank in forum Lathes, Lathe Rebuilding & ConversionsReplies: 27Last Post: 03-08-2010, 03:14 AM -
Mini Lathes and their capability
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 8Last Post: 02-08-2010, 05:29 PM -
Centre drilling with lathes...
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 12-09-2009, 12:01 PM
