  1. I use PM752 supplied with 65VDC. Transformer is 500watt.
  2. The Following User Says Thank You to wiatroda For This Useful Post:
  3. #12
    And the beakout board you use is pcpps from zapp automation? Because in the manuals for this board is written that it supports only max 35V? But the board is using the same voltage as drivers?
  4. Please see 1st picture on my website - Control box http://malamuterun.co.uk/cnc/homemade_cnc_mill.htm
    There is two power sources.
    1. Toroidal transformer with 25Abridge and capacitor at the top for PM752.
    2. 25V power supply at the bottom for PCPPS-3 from zapp.
    Two power suppliers share ground/negative.
  5. #14
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    Just looking at your proposed new drive system, isn't it bad practise to use two motors coupled together?
  6. Quote Originally Posted by m_c View Post
    So far the only problem I had it was when one of the belts snapped and then the other motor was pushing Y car's one side only eventually snapping the second belt or stalling the motor. That's why I decided to use one ,long, strong timing belt. Why do you think there may be any negative aspect of coupling the motors together ?? I've attached mounting plate pic. I'll try to produce it asap.
Name:	timing pulleys1.jpg
  7. #16
    Using two motors with one driving each side is ok, but I've seen it mentioned in various places that coupling two motors together can cause problems.
  8. #17
    Quote Originally Posted by primorc20 View Post
    Is this PM542 stepper driver? What voltage do you use?
    If you're deciding which driver to buy then get the PM752. The higher voltage will make the motors run with higher torque at high speeds, and thus faster overall.
    Currently I use the PM752 on 75v, though that should change in a few weeks when I've finished prototyping my 120v driver design...
    I'm also using a 500VA transformer with 4 of the 3 N.m motors.
  9. jupi machine alive again :))))
    First in order to cut proper steel motors mounting plate I've made "very sophisticated" 3mm MDF plate.
ID:	3760 Click image for larger version.
    I've put some corrections and CNC cut from 3mm steel plate, so far insides only.
ID:	3762 Click image for larger version.
    Some inside circle cut-outs are perfect to hold a material while machine cuts outside profile
    Just waiting for end result ;)
  10. #19
    i love it when a cnc makes it's self nice 1 mate keep up the good work. loving the pictures ;)
    there is no such thing as a stupid question, just stupid answers !!!!
  11. Thanks Chris
    ...and finished item
ID:	3767 Click image for larger version.
ID:	3765 Click image for larger version.
  12. The Following User Says Thank You to wiatroda For This Useful Post:
  1. BUILD LOG: jon's homemade cnc
    By jonbabbz in forum DIY Router Build Logs
    Last Post: 11-03-2021, 05:13 AM
  2. Funny machining pics
    By oscar in forum Workshop & Equipment
    Last Post: 30-05-2013, 03:55 PM
  3. Homemade CNC Project Help
    By chaslam07 in forum Gantry/Router Machines & Building
    Last Post: 04-04-2012, 11:53 AM
  4. Already built my machine.. but some pics of work etc
    By Yohudi in forum Gantry/Router Machines & Building
    Last Post: 31-08-2007, 06:15 PM
