    Quote Originally Posted by h4ppy-chris View Post
    you don't need a rotary table to cut the pulleys use your cnc to cut them out of plate ;)
    That does of course depend on the profile. You'd need a very small cutter to get a decent XL pulley with that method.
  2. Stuff have arrived. I managed to do some drawing . Hope tomorrow I'll find some time to put it together :)
ID:	3755Click image for larger version.
Name:	timing pulleys.jpg
ID:	3754Click image for larger version.
    Is this PM542 stepper driver? What voltage do you use?
  4. I use PM752 supplied with 65VDC. Transformer is 500watt.
  5. The Following User Says Thank You to wiatroda For This Useful Post:
  6. #5
    And the beakout board you use is pcpps from zapp automation? Because in the manuals for this board is written that it supports only max 35V? But the board is using the same voltage as drivers?
  7. Please see 1st picture on my website - Control box http://malamuterun.co.uk/cnc/homemade_cnc_mill.htm
    There is two power sources.
    1. Toroidal transformer with 25Abridge and capacitor at the top for PM752.
    2. 25V power supply at the bottom for PCPPS-3 from zapp.
    Two power suppliers share ground/negative.
  8. #7
    Quote Originally Posted by primorc20 View Post
    If you're deciding which driver to buy then get the PM752. The higher voltage will make the motors run with higher torque at high speeds, and thus faster overall.
    Currently I use the PM752 on 75v, though that should change in a few weeks when I've finished prototyping my 120v driver design...
    I'm also using a 500VA transformer with 4 of the 3 N.m motors.
  1. BUILD LOG: jon's homemade cnc
    By jonbabbz in forum DIY Router Build Logs
    Last Post: 11-03-2021, 05:13 AM
  2. Funny machining pics
    By oscar in forum Workshop & Equipment
    Last Post: 30-05-2013, 03:55 PM
  3. Homemade CNC Project Help
    By chaslam07 in forum Gantry/Router Machines & Building
    Last Post: 04-04-2012, 11:53 AM
  4. Already built my machine.. but some pics of work etc
    By Yohudi in forum Gantry/Router Machines & Building
    Last Post: 31-08-2007, 06:15 PM
