No problem, so the next question is...
Can you get a 1/2" Collet for the Makita and how well will it hold a 12mm shank (0.7 discrepancy) ?
You may get away with locking the collet nut nice and tite to take up that .7, however to save all the trial and error could you not use a cutter with a shank size you do have a collet for. Cutter diameter isn't critical here is it?, it shouldnt be because you could use a smaller cutter and make more pass's to get the finished trench width?
LeeLee
WANTED: Wanted: Cnc router at least 1200 x 1200 bed size
By swinds in forum Items WantedReplies: 1Last Post: 10-12-2012, 08:11 AM -
3040 size router plans?
By m_c in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 24-06-2012, 04:15 PM -
WANTED: ER20/25 straight shank collet chucks
By m_c in forum Items WantedReplies: 4Last Post: 24-10-2011, 12:19 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
What size (3mm shank) ball endmill should buy?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 16Last Post: 28-07-2009, 12:07 AM
