Thread: Leadscrew
16-03-2011 #13No, you just need to turn the screw slowly ;)Well the cutter carriage needs to travel at 2mm min and it needs to travel smoothly i.e moving all the time, so surely you need a very fine pitch lead screw to acheive this?
For your application all you need is to ensure any noise (vibration) produced by the screw is not transmitted to the cutter head (making a silent slide way for the cutter is the greatest problem you will have)
The lead screw itself need not be too special - I'd use a polished stainless steel rolled threaded rod with a PTFE nut for a home-brewed machine
I would use a servo motor and a simple speed controller with tacho feedback (a positional servo controller is unnecessary and would add noise to you machine)
I would use one or perhaps two stages of plain rubber belt speed reduction between the motor and lead-screw (stepper motors, gears and notch belts are noisy)
Are you going to use vari-pitch groove cutting? (i.e. making the groove spacing wider as (before!) the signal level increases)
Bill
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Cheapo Leadscrew with minimum accuracy requirement!
By Vikash in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 06-10-2010, 11:17 AM -
(Mini Lathe)Potecting Leadscrew
By GeorgeD in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 29-09-2010, 11:48 AM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
