Thread: Leadscrew
Ah, that changes things. Normally a stepper motor would be used as it's easy to set the feed on but you need a continuous feed not a stepped one (otherwise you will hear each step). How many revolutions do you get on a record? Is it the same spacing all over? Do you need to vary the spacing (IIRC there is a trade off on the groove width between quality and run time).
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Cheapo Leadscrew with minimum accuracy requirement!
By Vikash in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 06-10-2010, 11:17 AM -
(Mini Lathe)Potecting Leadscrew
By GeorgeD in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 29-09-2010, 11:48 AM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
