Thread: Leadscrew
You're not looking at high forces and backlash shouldn't be a problem as you're cutting in one direction so no need for a ballscrew. I think you're looking at a plain acme / trapezoid leadscrew with maybe a delrin nut. You'll want the leadscrew to be good quality so it moves smoothly and the guides for the cutting head should be quite heavy duty - maybe think about further damping the movement by using dovetail slides covered with a thick oil (I believe there are oils that are particularly sticky for that kind of application).
Good picture of a lathe on Wikipedia...
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Cheapo Leadscrew with minimum accuracy requirement!
By Vikash in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 06-10-2010, 11:17 AM -
(Mini Lathe)Potecting Leadscrew
By GeorgeD in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 29-09-2010, 11:48 AM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
