How do you think they'll compare to a Harrison M300? If I had a lathe that as capable as that then I'd be very happy. By capable I mean able to take similarly heavy cuts, accuracy etc.
I'm undecided with the AUD/CUD/BUD since if I made it CNC then having the autofeed is just a waste. The extra cost of the better lathe would buy the stepper motors, at least. Then again I want to be able to use it normally, and I did use the autofeeds an awful lot at school. [But don't tell the health and saftey inspector that. They disabled them when he came round!]
28-02-2011 #2
It's a good lathe, but it's not in the same league as the Harrison M300. The M300 is a larger and stronger machine, built for industrial use from the start. I see what you mean about the feed gearbox if you're converting to cnc, and you can use Mach to manually machine with the jog feature via the keyboard. One point to consider is the cost of converting the M300 is going to be higher than the Boxford, due to the larger physical size of the machine. You're also going to pay at least double the value of a Boxford for the M300.
28-02-2011 #3
As far as accuracy is concerned they should both be similar, but wear is a factor on both as they will be fairly well used.
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
Sieg Mini lathe - smallest diameter rod turn-able?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 18-11-2010, 01:15 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM -
WANTED: SIEG C3 Mini Lathe WANTED
By derekm in forum Items WantedReplies: 0Last Post: 03-08-2009, 03:02 PM
