Thread: How flat is a granite worktop?
When I worked with Corian,and similar, worktops we dreaded having to lift them once a sink cutout was in place.They were prone to cracking or even breaking from the corners of the cutout to the edges.We made a point of carefully sliding a similarly sized piece of plywood or MDF under them.I would think you ought to be providing a lot of support to a sheet of that size as objects of any significant weight may cause deflection.For aeromodelling,it may not be a consideration.
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM -
SWAP: Old Low res flat screen monitor
By cropwell in forum Items For SwapReplies: 0Last Post: 05-03-2013, 09:17 AM -
RFQ: flat work needed
By kristof in forum Projects, Jobs & RequestsReplies: 7Last Post: 24-11-2012, 12:00 PM -
RFQ: Flat work needed
By Ricardoco in forum Projects, Jobs & RequestsReplies: 6Last Post: 29-07-2012, 01:44 PM
