	06-03-2011 #17
Ok.... so had a day off yesterday but back today.....
I have changed and rechanged every setting I can find without any change in performance but finally I changed the "step pulse" to 10 and the "dir pulse" to 15 for each of the axises. The whole mill now sounds sweet without the "grinding" noises I had experienced from day 1. It actually sounds like other mills I have seen on Youtube etc.
I've run the top half of the sphere again and this is the result......
Note my cutter seems to get very close to the sphere on the roughing toolpath, this was something I didn't expect and a potential problem, I presume this is solved using longer cutters?
Thanks for all the advice...... I've learnt much following all your suggestions....... and above all found a cure for this problem.Last edited by Lee Roberts; 09-03-2011 at 09:21 PM. Reason: added image
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM -
backlash mack3
By h4ppy-chris in forum General DiscussionReplies: 9Last Post: 29-01-2011, 01:11 PM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Positive backlash???
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 18-08-2010, 05:04 PM -
Sieg C3 backlash problem
By Cret in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 08-09-2009, 07:18 AM
