Yes that's right. 2400mm/min is much too fast for your machine seeing as the x/y will only do 1500. Mach3 will automatically limit the feedrate to 1500, but still if your machine only just manages to rapid at that speed it's no wonder it looses steps with the additional force due to cutting.
I'd set the feedrate to maybe 800mm/min to start with and see how it goes. Be careful though - too low a feedrate and too high a spindle speed will burn the cutter. So check it's not getting too hot...
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM -
backlash mack3
By h4ppy-chris in forum General DiscussionReplies: 9Last Post: 29-01-2011, 01:11 PM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Positive backlash???
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 18-08-2010, 05:04 PM -
Sieg C3 backlash problem
By Cret in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 08-09-2009, 07:18 AM
