  1. #17
    Ok.... so had a day off yesterday but back today.....
    I have changed and rechanged every setting I can find without any change in performance but finally I changed the "step pulse" to 10 and the "dir pulse" to 15 for each of the axises. The whole mill now sounds sweet without the "grinding" noises I had experienced from day 1. It actually sounds like other mills I have seen on Youtube etc.
    I've run the top half of the sphere again and this is the result......
    Note my cutter seems to get very close to the sphere on the roughing toolpath, this was something I didn't expect and a potential problem, I presume this is solved using longer cutters?
    Thanks for all the advice...... I've learnt much following all your suggestions....... and above all found a cure for this problem.
  1. Micro lathe Zero backlash* conversion
    By Jonathan in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 22-09-2012, 10:56 PM
  2. backlash mack3
    By h4ppy-chris in forum General Discussion
    Last Post: 29-01-2011, 01:11 PM
  3. Sieg X3 backlash...
    By Vikash in forum General Discussion
    Last Post: 20-10-2010, 02:51 PM
  4. Positive backlash???
    Last Post: 18-08-2010, 05:04 PM
  5. Sieg C3 backlash problem
    By Cret in forum Milling Machines, Builds & Conversions
    Last Post: 08-09-2009, 07:18 AM
