04-03-2011 #1DuramaxHRTHandheldRetrofitTorch
DuramaxMRTMechanizedRetrofitTorch
DuramaxTM HRT and MRT Retrofit TorchesUpgrade torches for Powermax1000â and Powermax1250â systems
Summary:
Hypertherm is pleased to announce the availability of two new upgrade torches for Powermax1000 and Powermax1250 systems. Duramax HRT and MRT torches use the same superior, torch and consumable technologies as the new Powermax65 and Powermax85 torches.
Benefits:
Ordering
Information:
Duramax torches offer many advantages over older torch technologies
More durable: Proprietary, fiber-reinforced torch handle is 5 times more impact resistant and 20% more heat resistant to withstand the toughest metal-cutting applications.*
More reliable: Patent-pending Spring StartTM technology eliminates moving parts within the torch head for more reliable arc-starting.*
More life: Conical FlowTM nozzle and spring electrode deliver up to 55% more consumable life for up to a 30% reduction in consumable costs.*
Plug-and-play upgrade: Duramax RT torches use the same Easy Torch Removal (ETR) connection as standard T60 and T80 torches which makes retrofitting to a new Duramax torch simple.
Promotes consumable consolidation: Use one torch for both Powermax1000 and Powermax1250 systems and the same consumables as the new Powermax65 and Powermax85 systems.
Competitively priced: The new Duramax HRT and MRT torches are priced in line with standard Powermax1000 (T60/T60M) replacement torches.
*When compared with standard T60 and T80 torches/consumables for Powermax1000 and Powermax1250
Torch assembliesPart number
Duramax HRT hand torch assembly with 7.5 m leads**228788
Duramax HRT hand torch assembly with 15 leads**228789
Duramax MRT machine torch assembly with 7.5 m leads**228790
Duramax MRT machine torch assembly with 15 m leads**228791
BUILD LOG: 1250 x 1250 cnc router (from scratch)
By Danielroyal25 in forum DIY Router Build LogsReplies: 56Last Post: 08-08-2014, 07:35 PM -
Best CNC Lathe for £1000?
By Ratch in forum Marketplace DiscussionReplies: 2Last Post: 19-10-2013, 01:45 PM -
Brit made plasma THC for Hypertherm / Mach3 users
By stirling in forum Manufacturer NewsReplies: 3Last Post: 13-02-2013, 09:58 AM -
NEW MEMBER: Hello from Hypertherm
By Hypertherm John in forum New Member IntroductionsReplies: 0Last Post: 04-03-2011, 02:48 PM -
Hypertherm Plasma Cutting Systems
By Hypertherm John in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 04-03-2011, 02:46 PM
