    Isn't it ironic how I could do with a cnc mill to make the parts for my cnc mill? I know there's a load of timing pulleys dumped in a box at work. Will have a mooch through it when I get time. I certainly need to buy a rotary table or dividing head. Not really sure whether to get the Vertex HV6 rotary table or go the full hog and get the dividing head or just make my own rotary table with a standard industrial gearbox and indexing via a plate with suitably positioned holes.
    I guess timing pulleys could also be made with a home ground broaching tool. First of all, I need to find me a pulley so I can decide the easiest way to copy the profile...
    EDIT: B'jaysus, look what I found in me scrap bag. It's a 30 tooth with OD of 93.5mm and 30mm wide. Bit big though. Bummer. We have lots of them at work. Tooth to tooth is 10mm so I assume it's a 10mm pitch?
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. Warco VM18
    By PWD in forum Gantry/Router Machines & Building
    Last Post: 24-01-2013, 10:20 AM
  3. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 07:48 PM
  4. CONVERSION: Warco VMC Turret Mill - CNC Conversion
    By antsals in forum Conversion Build Logs
    Last Post: 07-03-2011, 12:25 AM
  5. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
