Thread: x-axis rails and lead screw
Just a quick question
Im finally getting around to building a router but im not sure on the size of the supported rails and leadscrew.
I will be mainly cutting acrylic and alloy and teh design thats in my head should be very stable.
So would 20mm supported rails be ok for a 48" axis with a 20mm ballscrew, originally i was going to go for 16mm all round for the leadscrews but i think the 20mm may give me less whip at higher speeds.
Thanks Adam
13-08-2011 #2
Hi Adam,
I think you're probably about right - I'm planning something similar, myself. No reason for not using bigger rails (25mm?) on the long axis, as they're not moving, but lighter for the gantry, of course; supported: definitely - can't see the point of doing it any other way - and why not just make them structural as well?
As for ball-screws, thinner limits the revs for whip, but thicker makes for greater inertia, i.e. limits acceleration, so it's a compromise (there was a discussion about this - with diameters/lengths and revs., on another thread, somewhere). But it all wants to be as concentric as possible, no obvious run-out or mis-alignment, good bearings; and well-balanced. Vibration analysis would be a Good Thing, if you can find someone to do it... (optional !-) Only just spotted your query, I'm new, too. Hope it helps."Just because Innovation is not universally accepted is not, in itself, proof of Superiority of Convention"
Robert van der Plas
z-axis - lead screw mount critique
By dsc in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 27-01-2013, 05:26 PM -
FOR SALE: linear rails and hi lead ballscrew
By John S in forum Items For SaleReplies: 2Last Post: 05-12-2012, 08:21 PM -
timing belt instead of lead screw
By deannos in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 06-03-2012, 08:25 AM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM
