Page 2 of 2 FirstFirst 12
    Quote Originally Posted by M250cnc View Post
    Your not agreeing with me are you.
    I use these belts on my lathe the Z is about 300mm BC
    I was cutting some tool steel and a bit too hard it pushed the bar in the lathe chuck but the pulleys are about £30/40 each, built it has awesome power. Backlash is 0.05mm
    Phil
    Sorry maybe I came across wrong there - I meant to agree with you!
    I meant to say that the laser cut pulleys and only 5mm wide belts were not good.
    I've used XL pulleys and 1/2" (some bigger) belts on my machines. HD belts would be nice...
    ...better than the X-axis nuns.
    Just noticed that typo I made - oops!
    Jonathan
    I was joking, as we always seem to be at loggerheads.
    Phil
    Sent from my HTC Desire using Tapatalk
    Thank you all!
    Jonathan,
    You have done exactly what I intend to do.
    Except that I was going to use an ACME rod.
    Where did you find this thing on the picture, enclosing the ball bearing?
    Did you get it machined?
Name:	Ball bearing.png
    Laurent
    Quote Originally Posted by LabSkis View Post
    I cnc milled it on my machine. I can send you the drawing/Gcode/make another if you like. I made it that slightly odd shape to fit in a tight space on the Z-axis before changing the router design somewhat and using it on Y. If I did another for the Y I would leave more material there for the bolts, and put a spring/belville washers on the bolts so that it rides over imperfection in the screw,
  5. #15
    OK. Thanx for your proposal.
    But I have nothing around here to get this thing machined.
    For the moment, I think I will stick to 0 backlash nuts like the one you find on dumpster cnc.
    Yet, do you think it has a real advantages on those nuts in terms of backlash or friction? Despite the Acme being worn by the roller bearing?
  1. Replies: 0
    Last Post: 25-04-2014, 11:35 AM
  2. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  3. WANTED: 12mm ball screw & nut
    By phill05 in forum Items Wanted
    Last Post: 22-06-2010, 09:26 PM
  4. Source of multi-start ACME or Metric Trapezoidal Leadscrew and Anti Backlash Nuts
    Last Post: 16-03-2010, 10:11 PM
  5. Stationary Ball Screw
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 29-12-2009, 01:12 PM
