18-03-2011 #8
I was being generous, so its even worse than i thought it was.
To drive a small PCB machine a belt drive like they use on the RepRap machines would do the job better, be easier to implement, would last longer and be far stronger. You also do not need angular contact bearings for the fixed end of the screw either. That is the HD 10mm pitch belts BTW.
Phil
eBay: TR12x3 Trapezoidal Metric HSS Right Hand Tap - Trapezoida Lead Screw Tap
By longy in forum Items On eBay UKReplies: 0Last Post: 25-04-2014, 11:35 AM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Source of multi-start ACME or Metric Trapezoidal Leadscrew and Anti Backlash Nuts
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 16-03-2010, 10:11 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
