Thread: DIY CPU water cooler
06-04-2011 #15
Jonathan got it right in an earlier post, and it looks so nice i didn't want to say anything negative.
Firstly i wouldn't touch the face of the CPU
You have three flaws in your design, it seems the wall thickness is to great the face touching the CPU should be in the order of 1mm or less
The flow of water should be controlled in a backwards and forwards motion in that it forms a single cavity from start to finish forcing the water to travel over all the surfaces
The size of the cavity should match the area of the pipe and within the cavity's should be fins for maximum heat transfer
For best heat transfer it should be made of copper
Air water etc will flow in the easiest route, in your design you can go from start to finish ports bypassing the edges allowing heat build up.
Phil
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Spindle Water Pump
By Tomnewry in forum Spindles & Drive MotorsReplies: 0Last Post: 11-08-2013, 01:05 PM
