Thread: DIY CPU water cooler
Looks nice, will be interesting to see how well it performs. I think it would be better to have thinner channels and more of them, but I'm sure that whatever you do will be far better than most air cooling systems.
What are you doing about getting the area where the block contacts the CPU smooth? It needs to be a very flat surface to work well.
I'm thinking of making one at some point. You can simulate the heat flow very nicely in solid works without too much effort. What socket is yours?
18-03-2011 #2
brings back memories, i used to overclock my PC's when i was younger, and had full water cooling to keep the noise down.
May be better to make it out of copper and also lap the underside to get it as flat and smooth as possible.Visit Us: www.automationshop.co.uk
18-03-2011 #3
18-03-2011 #4
Pics below shows a heat exchanger mount cut out from 3mm stell.
There is some more pictures & details of this project at my website:
http://malamuterun.co.uk/CPU%20water...ter_cooler.htm
22-03-2011 #5
Finally a clear pipe arrived today. I decided to try gravity circulating cooling system before I start to mess with any pump. At the moment of writing this a computer is on for more than an hour. Temperature of CPU is 33C. CPU usage is about the same like last time picture. So for now full success :dance:.
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
Spindle Water Pump
By Tomnewry in forum Spindles & Drive MotorsReplies: 0Last Post: 11-08-2013, 01:05 PM
