Thread: Ragged edges
You can use endmill's to cut wood with, single flue are the best for wood if using an endmill. HSS router bits also work very well, though don't last as long with some types of wood. I completely agree on going to birch or another higher quality plywood. I get mine ordered from a mill in bulk here in Scotland which is of no help to you at all. Best of luck and the varnish works, it just adds an expense and the time for the varnish to set.
Michael
23-03-2011 #2
I use quite a few of these Silverline TCT cutters. Cheap with a reasonable cut:
http://cgi.ebay.co.uk/1-4-SHANK-STRA...item2307ee4a3a
I've also recently bought, but not yet used, a spiral cutter a bit like this one. They shear the wood rather than rip across the fibre.
http://www.trend-uk.com/en/UK/trend/...ledge&id=15884
RFQ: Drill/Tap Guide Block for 15mm aluminium plate edges.
By Wal in forum Projects, Jobs & RequestsReplies: 11Last Post: 29-11-2012, 04:23 AM -
Milling experts, end mills cutting edges different lengths ?
By Smiler in forum Tool & Tooling TechnologyReplies: 2Last Post: 14-02-2009, 10:13 PM
