Thread: Sugestions For machines pleas
I am now looking at or for a small mid desktop milling machine with a auto tool changer.
Would like if poss for it to be R8 fittings.
The bed size would like to be x300-500mm y300-400mm z300-400
I dont know a lot about what machines are out there but DO need the tool changer.
Now for a lathe would like up to 300-400 between centres and a tail stock.
I turn very thin work 8.5mm over 180-250mm out of brass and ally. Thiswould also need a tool changer.
Does anyone out there know of somthing that could fill that spec?
If so please post and a like to your suggestion
Many thanks Rik
07-04-2011 #2
Rik with a cutting area that size you are looking at a Bridgeport and that is not a desktop.
For a toolchanger R8 is a no no unless you use the TTS system, i think DENFORD made some mills with a toolchanger but you need to make sure the holders are still available. The holders have to be one taper with a pull stud to hold them in place.
Lathes don't have toolchangers per sa they use a carousel, for the lenghts you will be turning you will need a tailstock with a revolving centre and it is debateable whether the carrosel would be able to rotate while the tailstock is in place.
I thought of making one for my lathe but you can only have up to six stations if your lucky more with a bigger lathe and i use over 30 tools so it wasn't worth it.
Phil
07-04-2011 #3
for the lathe a Denford orac would be a good buy, and there's a guy who does a toolchanger for it with 8 stations, the mill is going to be a big un, unless you could get away with a router.
NEW MEMBER: Pleas help mach3 and solid cam newbie
By gizmo333 in forum New Member IntroductionsReplies: 1Last Post: 24-03-2014, 10:34 PM -
CNC machines
By JMP in forum Machine DiscussionReplies: 2Last Post: 04-07-2010, 07:40 PM -
New CNC machines???
By afcpaul in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 18-09-2009, 01:46 PM -
cnc machines
By DGH in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 24-05-2009, 10:50 AM -
TEP CNC Machines
By alan2525 in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 05-02-2008, 01:04 PM
