Page 15 of 22 FirstFirst ... 51314151617 ... LastLast
  1. #141
    So by attaching the Larger bearing to the smaller shaft/gear/bearing combo, it raises the whole inertia dilemma? If there is a possibility of lowering the height of the machined gears to let the 7207 pass over it might work. But do you still believe it's cheaper, easier to bore out a $4.00 pulley?
    Mutzy
    thanks for the help
  2. #142
    Quote Originally Posted by mutzy View Post
    No. Changing the gear ratio raises the inertia dilemma.
    have to check that on some specifications but i think this was not possible. Willlook later at night
    Or you will have to redraw the rotating part and the aluminum block part/ all the parts/ from scratch. I dont know what to believe, depends how you value your time.
    Boyan, were you able to put some brain cells around the idea of keeping the same number of teeth, but lowering the overall height of the machined gear?
    Mutzy
  4. #144
    Mutzy
    Yes, you made me do it
    From table below we see that without changing anything, these 3 sized pulley will be possible to incorporate ion the rotating part without further change of components
Name:	pulleys HTD5 15.JPG
    So from these 3, it seems the best will be the P22-5M-15F . 22t is not so bad, outside diameter of the teeth is 35.01 so basically same as the 35mm of the OD of the part and the ID of the bearing. That will work.
Name:	rotating ball nut.JPG
    Not to have in mind that 400w servos and bigger have shafts starting from 12 if not from 14mm in diameter. So smallest pulley there could be even the 12 teeth, also 14, 16, 18, 20. But in reality could be also 13, 15, 17, 19, as i can draw the pulley with as many teeth i would like to and it suits me.
    from my Favourite belt calculator https://www.bbman.com/belt-length-calculator/ having in mind minimum distance from motor shaft to center of pulley is 90mm, and if bigger than 400W servo even 100mm, we could see that:
    12t puley is No good, less than 6t engagement
    But all puley more than 13t including are ok. Now it should be considered that the bending radius of 13t puley is too small, this for the durability of the belts. And believe me it will generate heat on the belt and pulley. But as belts is 3-4 $ its not of a great concern.
    So yes, it could be done. 13t pulley and bigger.
    now when you divide 22/13 , 22/14 etc. its not a whole number which i dont like. the first one that divides well is the 22/16=1.375 so nothing has to be rounded, 16t pulley i see as a minimum for a good bending radius. So that would be the one i would have used.
    Obviously 2x 750W servos at both sides will do the job and if something extreme is desired even bigger could be fit. having in mind gantry around 180-250 kg and max machine speed at 30m/min with acceleration around 3000m/s2 which is my machine tested and it really rocks. You should do calculations again for the specific scenario but more or less thats it.
    Also all time i am speaking of Samsung servos and brand servos in general. I have never tried the chinese servos but i think they will do well also. Plus really they are almost same price bigger or smaller/ servos must be correct size, not bigger or smaller /.
    It should be noted that when i am engraving small stuff i lower the acceleration at 1000, talking about aluminum stamps and so. But this is very delicate work which normally is done on a mill.
    I think that answers your question.
    Boyan
    Thanks for your extremely detailed researxh. Now i'll think about what i need to do, i'keep you posted thanks. Mutzy
  6. #146
    Boyan
    Remember that changing out a belt is no small project with the rotating nut design. So durability of a belt should be a big concern because of the downtime and hassle of disassembling everything in order to change out the belt. The whole ballscrew must be uninstalled to change a belt. No small task regardless of the size of the table.
  7. #147
    Quote Originally Posted by Black Forest View Post
    Exactly, that's why i said 16t as minimum. Everyday 8h machining belts would withstand at least say 2 years. Using it as a hobby machine at least 6-8 years.
    Thanks for all of the awesome input. i was preoccupied with other things, but now I can get backt to the design.
    Mutzy
  9. #149
    Boyan, how are you? sorry it has been a long time. I got the 22 teeth HTD drawn onto the shaft. The shaft is only .05 in thickness. is this too small?
Name:	Back view  with gear.jpg
ID:	23460Click image for larger version.
Name:	Back view  with gear 2.jpg
  10. #150
    I think its too thin. The clearance from screw has to be no more than 1mm, in fact mine is 1mm. so inside bore will be 25+2=27mm.
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. Replies: 15
  3. Rotating Ballnut Design MK3
    By Jonathan in forum Linear & Rotary Assemblies
    Last Post: 15-12-2013, 01:35 PM
  4. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
