  1. #9
    2) Optional
    3) Note that on the drawing I posted the motor mount is 88mm wide, not 90mm which is the height of the main block. I intentionally left a 1mm gap so that when the block is bolted to a flat surface, you wont end up with the assembly partially resting on the motor mount (if the motor mount isn't attached accurately). The gap is on both sides since I put mounting holes on both sides of one block so they can be mirrored.
    4) Very carefully. You use a 4-jaw chuck and a dial indicator.
    7) Same, that's fine.
    10) Or CNC4you if you want a cheaper option.
    Minor point - on your drawing the 6 tapped holes that fasten the ballnut to the mount go all the way through the flange on the shaft. I made them blind holes so if you accidently try to use too long a bolt, the bolt doesn't go all the way through and damage the bearing.
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. Replies: 15
  3. Rotating Ballnut Design MK3
    By Jonathan in forum Linear & Rotary Assemblies
    Last Post: 15-12-2013, 01:35 PM
  4. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
