Page 11 of 22 FirstFirst ... 91011121321 ... LastLast
  1. #101
    vre's Avatar
    Lives in Athens, Greece. Last Activity: 19-05-2022 Has been a member for 9-10 years. Has a total post count of 39.
    Very nice the idea of rotating nut!
    I want to convert a conventional lathe to cnc and Z axis leadscrew has 1900mm length 30mm diameter.
    If i use L1900mm 3210 rotating ballscrew with 2 bk25 end supports i will have 1300rpm citical speed & column strength 28477 newton
    The critical speed is ok to me because i will get 10m/min rapids with 1000rpm in ballscrew i have concern about column strength because 28477 newton (2900kg / Z axis servo can give 3400kg ) isn't to big force and also i have fear about sag to 3210 ballscrew and runout at rotation that will do a lot of vibration.
    In my situation would be better a rotating nut design like this to overcome these 2 problems (column strength & ballscrew sag/buckling) ?
    Also with rotating nut design can i use a lower diameter ballscrew without having whipping ?
  2. #102
    Jonathan and all of the determined mad scientists and hobbyists of this forum. This is great work. I really appreciate you sharing the setbacks and successes of hard work. Keep up the great efforts...I learn so much from this. Thank you again......Mutzy
  3. #103
    Jonathan, how are you?
    1. Where did you get the pulley that is associated with post 79? Was it machined out with a larger bore to fit the shaft or store bought? Where can i get one?
    2. I see that there are two different shaft configurations with the pics. One the shaft where the ballnut attaches sits kind of deeper in the cupped out area, and the other sits flush with the whole face. what is the reason for this.
    Thank you so much for your time.
  4. #104
    Quote Originally Posted by mutzy View Post
    I used a standard pulley and bored it out to the size of the shaft.
    This shaft where the face is 'cupped out' leaves a surface to locate the ballnut concentric to the shaft. This works well if the ballnut is accurately machined, but I found that you can't necessarily rely on this so sometimes it's better to just go with a face and align the nut with a DTI.
  5. #105
    Thank you Jonathan. What is a DTI?
    Mutzy
  6. #106
    Mutzy
    Dial test indicator https://www.machinemart.co.uk/p/cm22...c4FBoCNljw_wcB
  7. #107
    e.g:
  8. #108
    Hello Jonathan, Do you not accept PM? I would like to contact you.
  9. #109
    Jonathan do you sell these to other people at all or know anyone specifically who can make the from drawings?
    cheers
    Ash
  10. #110
    Hello Jonathan, how are you today? Wow, you certainly created a great thread here. I can't seem to find distributors that have this size bearing to bore out. Do you have any suggestions of who might sell them? USA would be best for shipping. Once again thank you.
There are currently 17 users browsing this thread. (0 members and 17 guests)
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. Replies: 15
  3. Rotating Ballnut Design MK3
    By Jonathan in forum Linear & Rotary Assemblies
    Last Post: 15-12-2013, 01:35 PM
  4. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
