Thread: Rotating Ballnut - design ideas
20-05-2020 #22
We will have to agree to disagree regards a wooden CNC machine.!!
Regards the 16mm screw then it's too flimsy over 3mtr and thou it it doesn't rotate it will still vibrate at higher feeds. Now you probably don't believe me because your thinking well it's under tension how can it.? But let me assure you that it will vibrate because even the 25mm screws I fit and put under heavy tension still vibrate at high feeds when the machine approaches the ends of travel and changes direction quickly. A 16mm screw will twang like a skipping rope.!!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
