Thread: Rotating Ballnut - design ideas
11-02-2022 #35
Hi Martin, welcome to the forum!
Afraid I don't have the knowledge to answer your question with certainty, but my gutfeel is that 2010 would be sufficient with the ballscrew being stationery as you plan on using a rotary nut.
Hopefully a knowledgeable member will notice your post and give you an authoritative answer over the weekend.
Jonathan's Rotating Ballnut is the only thread I've seen on this subject, so they seem to seldom be used on DIY builds.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
