Thread: Rotating Ballnut - design ideas
I was thinking it's best to eliminate as much play as I can. In that case it's either the design #13 or #7. The latter, with one bearing, is easier to machine and cheaper, but less stable and bigger pulley. I'm worried about getting the centre height in the design with two bearings accurate.
I've worked out that linearmotionbearings only charges £18 per RM2510 ballnut (and about £31 per meter of the screw), so it's not much more to have a second nut. Friction is a good point since the whole idea of this is to make the machine run faster.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
