Thread: Rotating Ballnut - design ideas
03-07-2011 #10
Thanks :). I hope it works well after all this... I modified irving's spreadsheet to include pulleys and used it to model this setup. Looks like, with the 3Nm motors I'll get at best 7500mm/min rapid and 2000mm/min with 50N cutting force. Both of those are a lot lower than the prediction for the Y-axis, 18100mm/min and 8200mm/min. All of those figures are with a 3x safety factor on the torque, so fingers crossed it might be better!
I'm currently making a mandrel from 35mm steel bar to hold the shaft in the rotary table/4th-axis to mill the pulley teeth on to it.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
