Thread: Rotating Ballnut - design ideas
04-07-2011 #11
I'm using XL belts, purely because I already have lots of XL timing pulleys which will enable me to experiment with the ratios. HTD would be better in theory.
I will use a form tool to cut the pulleys. The profile is a simple trapezium which I have ground on to a piece of HSS. You can make HTD pulleys accurately with a ballnose cutter ... or some people use a drill but I think that's a bit crude.
If you do decide to try it you might find my program here useful:
http://www.mycncuk.com/forums/showth...ating-programs
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
