Thread: Rotating Ballnut - design ideas
06-07-2011 #10
Thanks for the kind words...
I just mounted one ballscrew to the frame with a couple of G-clamps and some wood, so not the best but it holds. So with one ballscrew and 3nm motor I'm getting at least 12,000mm/min! It might do more but things are wobbling a bit as I have not fixed the X-axis linear rails down to the frame.
With the previous rotating nut setup (see post #1) using M20 threaded rod the best it would do reliably was about 2500mm/min.
The gantry hasn't got the spindle and Y axis screw etc mounted, so it's only about 40kg not 50kg, but still looks very promising. It's odd since for this motor and pulley (28T on motor, 30T on screw) I calculated 7300mm/min.
Will post a photo in a few mins.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
