Thread: Rotating Ballnut - design ideas
27-11-2016 #11
The heat comes from the motors. We like to use big macho-Volts to overcome inductance which leads to eddy currents and heat. The problem is, what to do with the heat? You want to dump it in to the machine before your motors demagnetise, but you don't want to get it in the screws because you would be forever worrying about heat expansion.
Will you be oiling those taper rollers? I occasionally run oil down in to my spindle bearings and make a terrible mess. That's a thought maybe it is his choice of lube that is creating the heat.
There are currently 12 users browsing this thread. (0 members and 12 guests)
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
