Thread: Rotating Ballnut - design ideas
08-10-2017 #11
Hows that will not fit? Over no, but there is a sequence of pressing the parts together. That's why the pulley is bored from a separate pulley and then pressed together. if you machine right on shaft, then you will have to machine a smaller pulley so the bearing passes on top of it. But then the ball screwe size pass trough hole, so you will have to check if that's at all possible. I believe it was possible but not sure now. Have to check
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
