Thread: Help! Moving a big lathe...
Yes, I read about that a while ago hence why I'm reluctant to do that.
If I noted where each shim went, then carefully put them back in the same place would that work or might taking the bed off twist it a little differently? I can measure it by turning a long length of bar, checking the diameter is constant and using the DTI to check it is parallel. Or is there more to it than that?
13-04-2011 #2
13-04-2011 #3
Just out of interest have you done it before?
How much difference do you think it will make to the machine, given that I've never needed to turn anything longer than 250mm and that was a one off? Can't you compensate for twist to an extent by putting metal spacers under the corners of the stand?
This is what we've got to negotiate:
13-04-2011 #4
Jonathan your scenario is a lot harder than mine mine was a straight path, my path is more substantial than yours looks.
Taking the stand off will reduce the weight but i guess if you stripped every thing off you will only shave off 25% of the weight.
The lathes are shimmed & mounted to take out twist in the bed this is done by measuring not cutting that is why it is not to be attempted without the right equipment.
No i haven't done it on a lathe but i did on my small Taiwan mill and they are not in the same class "Junk" is how i would describe them, so no great loss.
Phil
13-04-2011 #5
Jonathan,
An engine lift will do nicely to move the lathe. I used a 2 ton lift to get my lathe into my workshop a few weeks ago. I had to cross a gravel area for around 6mts before getting to the stairs of my workshop. I used 40mm thick interlocking flooring boards at 600mm wide by 2400mm long to give a running surface. When I got to the stairs I then spanned then with 6 of 100mm x 100mm fence posts to support the weight. Then the lathe was lifted around 400mm high and placed on the posts running up the stairs. Then the lifter was moved inside the workshop and used to pull the lathe further up the ramp to get it in position for a straight lift to go to its final position. This worked very well and just required care and attention as with all lifting procedures. The thing to remember with engine lifters is that they cannot work outside their footprint.
Best of luck.
Regards
Ian
Moving Heavy Machine
By bobhome in forum Machine DiscussionReplies: 10Last Post: 09-09-2021, 11:41 AM -
axis not moving when running code
By geny in forum Computer SoftwareReplies: 0Last Post: 21-10-2012, 08:02 PM -
moving mach3 help please
By h4ppy-chris in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-03-2011, 07:33 PM -
Moving a new mill
By abfa9358 in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 07-05-2010, 11:27 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
