Thread: Help! Moving a big lathe...
a pallet truck will give you a better rolling surface, but the hoist and legs of an engine hoist often give you more versatility. I've moved a few harrison m300's with an engine hoist, and you can drop the lathe onto the legs for good stability. Two full sheets of 18mm ply should do the trick, as you pass onto the second sheet move the first around to the front. A strip of 10mm ply under the joint will stop the sheets seperating when the wheels go over the joint.
12-04-2011 #2
Thanks for the advice everyone, I'll show my dad this thread and see what he thinks.
We've got plenty of logs for the fire. I'm thinking if it came to it I could turn a few of them on the wood lathe to make rollers and do it Egyptian style!
Moving Heavy Machine
By bobhome in forum Machine DiscussionReplies: 10Last Post: 09-09-2021, 11:41 AM -
axis not moving when running code
By geny in forum Computer SoftwareReplies: 0Last Post: 21-10-2012, 08:02 PM -
moving mach3 help please
By h4ppy-chris in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-03-2011, 07:33 PM -
Moving a new mill
By abfa9358 in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 07-05-2010, 11:27 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
