Thread: Ballnuts
04-08-2011 #19
Yes my deflection example is wrong when the total force applied to the nut is below preload threshold, my mistake.
But having preload rated against cutting force (ie force resulting in the cutter itself) is not enough! don't forget that you have also a motion!
There is force needed to achieve proper acceleration, and this add to the cutting forces.
Once you are above cutting forces, you need to have highest rigidity possible: shortest and strongest spring possible.
Having a very very high preload itself is not always the way to go: higher wear, need more driving power due to loss.
1605 ballnuts
By dudz in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 30-03-2013, 09:31 AM -
FOR SALE: 2x 2005 C7 Ballscrew 1450mm Length with Ballnuts + FK/FF mounts and motor coupler
By Shinobiwan in forum Items For SaleReplies: 38Last Post: 31-12-2012, 02:42 PM -
Securing and Aligning Ballnuts
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 29-09-2012, 11:39 PM -
What oil for ballnuts?
By Robin Hewitt in forum General DiscussionReplies: 1Last Post: 24-10-2009, 08:36 PM
