Thread: 75 mm HAND WHEEL
14-10-2008 #1
This project uses a 12mm or 1/2” thick aluminum plate or round bar to create a hand wheel.
If using cutoff round bar material you may need to square it up in the lathe first. Drill through the center of the material with a 5.0mm drill and thread with an M6 (6mm) tap. This serves to bolt the aluminum to a piece of material that can then be clamped to the machine bed.
When complete the center hole can be drilled or reamed out to the size required. The file's provided will machine the basic shape, other details can be done manually to one’s own requirements.
The G-Code file to machine basic wheel shape using a 4mm slot drill and a pdf of the part are attached to this post below. The part is quite a large file and may take a couple of hours to complete, if a lathe is available you could also turn the wheel for a final finish.
This was originally provided by Roy over at www.diycnc.co.uk, He also has some other cool projects too.Last edited by Lee Roberts; 18-03-2012 at 12:45 AM.
RFQ: Ferris Wheel
By cockneyrebel in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-02-2014, 10:00 PM -
MPG or Hand Wheel Pulse Encoder where to buy in UK?
By suesi34e in forum Marketplace DiscussionReplies: 5Last Post: 02-01-2014, 04:41 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
RFQ: Aluminium wheel Adapters needed
By 1username in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-02-2010, 10:50 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
