Thread: Cutting out a circle
Hi my hand router broke and I need to program my ELU 860 CNC by hand as I have not got it working from the computer yet. I need to do a circle with a 90mm diameter and a cut out depth of 18mm. Can any one tell me what code I need to insert to achieve this?
I would appreciate any help.
18-04-2011 #2
I'd be inclined to spiral down counterclockwise for a hole, clockwise for a spigot. The only missing data for a G code is tool diameter and start point.
If you program a G code arc which ends at it's start point the machine goes full circle.
The Following User Says Thank You to Robin Hewitt For This Useful Post:
19-04-2011 #3
hi'ya martin, not 100% sure but see att.pdf, it's a long time since I did anything on an ELU-kelef WARNING check your +/- directions and abs/inc in program. you can post a sample program to be checked
The Following User Says Thank You to kelef For This Useful Post:
Aluminium cutting
By Bush Flyer in forum Metalwork DiscussionReplies: 55Last Post: 13-05-2016, 09:57 AM -
Cutting Ply/MDF
By Leadhead in forum Wood Finishing Tips & TricksReplies: 3Last Post: 02-10-2013, 01:59 PM -
control signals to draw a circle
By lakmalp in forum Machine Control SoftwareReplies: 3Last Post: 16-06-2013, 05:52 PM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
PCB Engraving / Cutting
By jrob3rts in forum General DiscussionReplies: 6Last Post: 02-06-2011, 09:35 PM
