    Quote Originally Posted by i2i View Post
    have you tried the engineers merchants like cromwell, mscj+j, buck and hickman, ect.
    I've tried J&J and Cromwell - they're £50-70, seems a bit much. I can't find any at buck and hickman, do you know of any others?
    Little lathe cheap parts, big lathe expensive parts
    I have various holders the next size down from various manufactures from original to new Chronos types
    The newer ones are very flimsy which i only use for small boring tools etc the older beefier types for the bigger tools.
    One thing i can say is hardly any fitted correctly which wasn't an issue when manual turning, but when i went cnc those errors were unacceptable and i had to grind the tool post and all the holders, now changing tools i can hold a tolerance of 0.01mm on diameter.
    The other place is ebay i still want more so i may make my own in the long term.
    Tooling can cost more than the machine, currently i have 26 plus the tools in them + insets = 3 to 4 times the cost of the lathe.
    Phil
    I got one of the holders from Chronos for £26.95:
Name:	DSC07273 (Medium).JPG
    It seems to fit well and is 'solid'. Even at that price it's going to cost a fair bit to get enough (though not 26!), and it's going to take a long time to make my own.
    There's a version of it here with the proper square bolts:
    http://www.rdgtools.co.uk/acatalog/Q..._Holders_.html
    Slightly more expensive but I might get one and compare.
    Jonathan that toolpost in the picture is 180 degrees out. :confused:
    If you are doing manual then yeah you don't need too many but cnc it takes so long to set them that it is worth it in the long run.
    Phil
    Quote Originally Posted by M250cnc View Post
    Yes it is, didn't matter for what I was doing though! I realised what I'd done once I'd put the tool in...
    No doubt I will convert it to CNC soon.
  1. Rotary broach tool holders and tooling
    By dazza in forum Tool & Tooling Technology
    Last Post: 06-12-2014, 01:06 AM
  2. Ignoring tool change
    Last Post: 15-02-2014, 06:34 PM
  3. ER11 quick change system ?
    By routercnc in forum Tool & Tooling Technology
    Last Post: 21-01-2014, 10:11 AM
  4. Mach3 Tool Change Position
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 15-07-2013, 06:54 PM
  5. XYZ Centurian 450 VMC tools sticking during tool change (M06)
    By craftydonkey in forum Milling Machines, Builds & Conversions
    Last Post: 19-10-2011, 03:11 PM
